SignUp Now!Then he better stay home
Thats right Gary,Whats a little more hot air between friends anyways.Certainly hot-airs are welcome. See you there.
That would depends upon what end the hot air is coming from, Lou.Thats right Gary,Whats a little more hot air between friends anyways.
lol Gary you're too fast on your feet for me.That would depends upon what end the hot air is coming from, Lou.
Double barf & double enema both.
110K mile car, look at the bumper fillers, steering wheel, & driver side seat where the driver slid into the seat rubbing the upright outer seat cushion. Dash gives it away too. If you're bringing that piece of junk, you're not parking with the crew.
01) Rafael Vasquez (TB.com)
02) Gil (1986TR) (TB.com)
03) Gary Wells (cf.com &TB.com))
04) Mike Barnard (SPOOLFOOL2) (TB.com)
05) Michael (mikalanjavin) ((TB.com)
06) Alan (ILikeSix) TB.com)
07) Tim (Meanchicken) (TB.com)
08) John (blackax) (cf.com & Motorgen.com)
09) Bob (jedhead) (cf.com & Motorgen.com)
10) ????? (kdracer73) (Motorgen.Com)
11) ????? (turbobooster) (TB.com)
12) Lou (turbolou) (TB.com)
13) Lee (cruzn57) (TB.com)
14) Jeff (Jeff Rand (TB.com)
15) Ernie (lunarx) (cf.com)
I'm officially cursed.
I blew out a header gasket Thursday,....big piece....sounded freakin' nasty when it happened. Once I was sure that's what it was, I drove the thing home a couple miles making all sorts of racket.
While I was nursing it home trying to take all the back streets so fewer peeps would have to listen to it...as I was doing this, my brake peddle suddenly went soft.
So anyway...I decided to go without a header gasket on the passenger side and did that job today...problem is....still have a nasty leak...not as bad, but the header needs a gasket.
The brake issue was a banjo bolt on the back of my passenger side front caliper. Guess I didn't tighten it enough when I swapped calipers a few months back, so it loosened up and let some of the brake fluid out...tightened it up...added fluid...bled the brakes....that issue is fixed.
The car is drivable....but sounds homeless due to the header leak, so I'm out.
Ordering new Remflex's tonight...
