turbonut85
Rarely used member
- Apr 11, 2008
Most of us agree the Powermaster brake system is unreliable and expensive to repair. So for those who want to do the Hydroboost swap, here goes.....
You have two choices:
1. pick up a used system off another turbo car. 83-84 TR's sometimes 85 too.
2. go to the local parts store (NAPA, Oreilly's, Autozone etc..)
---if using option 2, have the parts guy look up the parts under 1984 Buick Regal 3.8L turbo, VIN 9...and SHOP AROUND!!! prices will differ greatly between stores!!
Parts needed:
you will need:
-booster
-master cylinder
pressure line (pump to HB)
pressure line (HB to steering gear)
3/8 return hose
-you can get these from the local parts stores (NAPA, Autozone, Oreilly's etc.)
Master Cylinder
Cardone 10-1984
Hydrobooster
Cardone 52-7211
Hose (pressure: pump to hydroboost)
Duralast 91660
Hose (pressure: hydroboost to gear)
Duralast 71187
Hose (return: 3/8" bulk transmission hose)
Gates
4'
T fitting
(standard 3/8" vacuum T)
Hose clamps
3/8" hose clamps
6
Brake fluid (DOT 3-4)
1 quart
Parts needed:
you will need:
-booster
-master cylinder
3/8 return hose
Master Cylinder
Cardone 10-1984
Hydrobooster
Cardone 52-7211
Duralast 91660
Duralast 71187
Gates
4'
T fitting
Hose clamps
3/8" hose clamps
6
1 quart
