There are several other things to consider than $$$.
1.Is your car T-top car?
2.Do you run the Metco type trailing arms?
3.What are you doing with the car, street or race?
4.How many times have you tried to save a buck and end up spending more in the long run?
I have had to answer all these questions several times.
1.If it is a T-top car, the HR is the one you want. It makes the car as solid as a hardtop car , especially at the track. Keeps the car from twisting and handles like a dream.
2.If you run the BIG Full Throttle bar with the Metco type arms and the poly bushings, you MUST space the bar correctly when installing. Washers have to be used as spacers, (usually stainless washers because they are thinner allowing more or less to be stacked together to fill the space) to fill the gap and keep the geometry correct. The bar tends to pull the arms in and rip out the bushings rather quickly. Usually within a few 100 miles. If the bar happens to be tight and is spreading the arms, same thing, only no way to fix other then to grind bar on the flat area so it slips in without needing to be forced in. Stocked boxed arms with poly bushings are stronger so dont sweat it. I am just putting out some info for others reading this thread.
3.If you are driving mostly and not launching with a trans brake or ton of boost, the HR may be over kill, but still well worth the feel for just driving in my opinion.
4. My favorite piece of advice to anyone. I dont know about you guys, but anytime I ask for opinions and someone pops up with a cheaper alternative, it always costs me more because I should have got the better one to start. In my case, it never fails. I usually end up with the cheaper one for sale and the one I should have got first, on the car.
I have owned all. Stock, 1 3/8 Full Throttle and HR. The HR is pricey, but Paul makes his stuff in his shop and it is well worth the $$$. Buy it and install it. If you dont like it, it will sell in less then 5 min in the for sale thread.
:biggrin:
