- Aug 10, 2009
With the tr6 I don't recall putting power to d11. It was power to the orange wire of the 2 step which is the trigger.
SignUp Now!If you have 12v to D11, it will shut off closed loop correction. You need to double check what you did, as it sounds like you sent 12v to D11 all the time (instead of only when the 2-step is active).
That's awesome!! Wonder how many have been that fast on the stock ECM??I was at bowling green. Had someone run 9.13 with a SD2 and E85.
Only 60 people running the SD2 , so that means a lot on what that chip can do!!!
Only 60 TR's? Wow! I'm surprised. Or is that just atBG?
It would be nice if there was an add on controler/readout similar to the edash. With auto connectivity, logging and tune sto
there are some developments with tablets and stuff going on right now, so these kinds of things are coming.
there may only be 60 or so SD2's (its probably higher now...), but these kinds of things help all the PL users, and there are LOTS of those.
Bob
Cool.
Or even better a replacement gauge cluster
