Thanks to all for quick response. I'l try to answer all without quoting each separately.
1. I watched 2 full-time lots-of-eperience trans installers tighten them, but I could take it back and ask them to check 'em. I had 2 tc bolts let loose on me years ago when the car had only about 19 k miles (36k now). Thought I threw a rod!
2.It's an old (5 years) SMC controller, with an even older Jay Carter Alky Kit pump (the first ever produced I think
Been running on and off since I bought it...let's see I picked it up at the NATS that time they were held in Columbus...96? Combined about 20k miles on 2 cars since. Been planning to upgrade to Razors kit over this winter, but don't want to do that prior to making sure so I don't still have the issue after the new kit is in. Did you mean you "hot wire" the pump with a relay? Otherwise how do you control turn on and pump speed? What pressure am I looking for? Do I check with it flowing or dead head the line?
3.Pump speed is maxed, initial has been fine at 10-12 psi for years. Also since I've tried "holding" the boost at 12 while the alky gets flowing during the testing I was doing, then creeping it up, and KR increases, seems to indicate an alky or fuel volume issue has crept in??
4.Since it seems odd that the converter would cause KR, it sounds like real KR to me and my alky pump is ancient, I started thinking perhaps incorrectly in that groove. I've read lots of Razor's instrux over the years (printed most!). I'll search for what you mention and pour over it. Other stuff in sig. Something must have broke, plugged, failed, opened, fell off or weakened..don't you think? Is it possible for the converter to cause KR under heavy load?
If this needs to be moved so be it. I like the feedback so far!
Thanks again. I'm on it. I can't wait to get to the track with new converter.
Joe
