- Mar 1, 2005
Are the heads stock? Maybe a set of ported heads and an intake would put you there....
SignUp Now!Focus on the 60' times.
Set your pinion angle to -1.5 degrees. Remove your front sway bar. Install drag shocks front rear...cheapy Lakewoods have done well. Comp Eng makes some good cheapys too. Also installl some Moroso trick springs front/rear. Loosen your front end control arm nuts and focus on getting maximum wheel travel in the front end. Remove shock stubbers up front.
By doing these things I went from 1.7's to 1.46 as my best to date. This is on the Malibu you see launching in my sig.
Good times so far and some good recommendations in here also.
Since you want it too look stock then doing the Steve Monroe 62mm throttle body port is something that would help a tad and not look any different.
It sounds like you were locking the converter in 3rd so stick with that and forget the transbrake unless you want to collapse that stock forward drum.
Also agree on adding more psi in the tires, the top end should stabilize and maybe gain you a 1/2 a mph.
Definitely add more timing in 1st, which will probably help the launch also and make sure the alky is not coming on out of the hole, you might need to talk to Razor to tweak the kit.
While you are talking to Razor, see if he recommends going to a twin nozzle to get those temps down. Might only be an M15 and an M5 but it should get you lower than 200 degree inlet temps which means, more boost!!:biggrin:
I didn't see any Scanmaster or Powerlogger data etc, but I'm curious on your AF/R, you might be able to sneak another MPH if you're running too fat.
An aftermarket Maf like a 3.5" would help a tad as the inlet will have much less back pressure.
I always read -2 to -4 degrees of pinion angle. Any reason for -1.5? Front sway bar is already gone, and have QA1 single adjustables up front (set to 3). I'll get some QA1 single adjustable rears. I'll research some trick springs on all four corners. How much do I loosen the front control arm nuts? Will affect street driving? What does removing the front shock stubbers up front?
Thanks for the info.
Doug D
Hi,
You guys are a hoot. As a non drag racer,I am impressed with the stuff I learn,just by reading your posts. I would race for the fun of it, but you guys are serious! Bless you for that, wish my competitive spirit was stronger. Now, let me go find a ricer I can beat up on...
I thought 11.5 AFR was too lean for meth injection?
I'll look into modifing the front end to get the best weight transfer.
I let the car shift itself by putting into drive (not OD). I think it shifts around 4900.
Doug D
