Scott4DMny. You heard me correctly. 0w30 doesn't function properly when cold.
Turbo6Smackdown, you couldn't be further from the truth.
I'm going to explain this as best I can in a brief paragraph. Just to be clear NO ENGINE OIL GIVE YOU PROPER PROTECTION WHEN COLD!!!!
To start you should know the industry standard for checking the viscosity of oil is 40c and 100c respectively.
Take for instance if you run redline 10w-30. It has a cs (viscosity) rating of 10.7 at 100C. Now look at Amsoil 0w-30. It has a cs rating of 10.44 at 100C. So what's the difference? This difference is the base oil used to make them. The redline starts with a 10 weight oil and ads viscosity index modifiers and the Amsoil starts with a 0 weight oil and does the same. What this means is that in the case of the 10w-30 the oil when cold gets as thick as a 10 weight oil but as it warms up to operating temperature
it only gets as thin as a 30w oil. The same is true of the Amsoil but with 0w oil.
See, if you start at 40c with a 30W oil you'll have an approximate cs of 100, or ten times the desired viscosity and at 100c you'll have a cs of 10. That's why they start with a lighter oil and modify it so it doesn't get as thin. That way they get better flow when cold (although still not good enough) and they still get the desired flow at operating temps.
Now lets take a look at the two oils mentioned above.
The Amsoil at 40c (104f) has a cs rating of 56.39, or about 6 times thicker than desired but a cs of 10.44 once warmed to 100c.
The redline at 40c has a cs of 70, or about 7 times thicker than desired but a cs of 10.7 once warmed up.
Both provide inadequate protection during startup at 104 degrees fahrenheit and desired protection at operating temperature. The only difference is one provides better protection at startup.
FWIW, one main reason for changing your oil is that the viscosity modifiers break down with time and use and the oil reverts to it's base state. HTH. james
