So what will happen with Bison's car tomorrow?
What will happen?
  • Car will run bottom 10's and drive on the trailer
    Votes: 25 33.8%
  • Car won't even make a full pass and explode
    Votes: 10 13.5%
  • Car will make a 9 sec pass because we get greedy and turn up the boost past 25
    Votes: 35 47.3%
  • Car wont even make a full pass casue of issues
    Votes: 4 5.4%
  • Total voters
    74
My trailer is at Joe's if you need it.
Your track record speaks for itself......."because Otto broke it"
I say 9.70s
Billy T.
gnxtc2@aol.com
Thanks Billy. I really appreciate that. 9.70's? Probably not at the boost I ran on the dyno. Maybe at 30psi.
I think you will get it. Good luck. The only thing that might hold you back is the weather.
Wednesday: Scattered showers and thunderstorms, mainly between 1pm and 4pm. Partly sunny, with a high near 83. West wind between 6 and 8 mph. Chance of precipitation is 30%. New rainfall amounts of less than a tenth of an inch, except higher amounts possible in thunderstorms.
Wednesday Night: Partly cloudy, with a low around 57. West wind around 7 mph.
Car will make a 9 sec pass because we get greedy and turn up the boost past 25. Get a video of this.
Brian if you run 9.88 or better the strippers are on me when I come to drop off my car to you
Sounds like a good reason to go tonight. I owe you a ride home from the last time i raced and my u joint broke and wiped out my tranny case. You need a helmet or did you finally get 1? If you need anything let me know
If the weather conditions are favourable you'll crack the 9's. Either way guys...have a fun evening...cuz at the end of the day...that's what it's all about.
I'm callin a 9.90 right offthe trailer without changing the tune sense the dyno pull. It defiantly has the power for it without adding anymore boost
40% chance of thunderstorms, some last minute thrashing,Bison is installing a new seat belt, i am installing a Bailey 2 step.....
should be leaving shortly
Don't forget video and said shovel.........:biggrin:
Good luck.......9.80
Otto, maybe I missed it but is bisons Gn a chip car or does it have xfi If chip what version 6.0? I wanna upgrade mine for the target a/f option
I thought it was going down yesterday. I woke up at 3:30am and grabbed the phone to check this thread LOL!! Can't wait for results!
hello; I forgot to ask was the car dyno tuned?
IBBY
It was turned up to 609whp on the dyno. It made about 25.5psi on the dyno. I expect 27psi on th pavement.
