 - Jun 6, 2001
Injector lights flash on and off, crank and cam lights blink on and off on FAST.
SignUp Now!But are you getting fuel? Pull a plug. Is it wet?Injector lights flash on and off, crank and cam lights blink on and off on FAST.
I never had a problem with this. Then again, all my coils were good to start. TR-6 and XFI work well together for me. But I was going to recommend checking the dip switch settings and LED indicators in the TR-6. But you have already put back on the stocker. So, I guess that can't be it.back in July both Cal & Bob said to pull off the TR6 as sometimes it does not work with FAST.
Get rid of of the XFI. You can put my $200 toward the new Holley Dominator lol!I'll send 200.00 to whomever can figure this out.
Mike
This is a pic of the dash, key on engine off and a pic of the cranking fuel graph. Cal set up all the tuning.
I don't have any fuel pressure sensors, just a gauge on the rail which shows 41psi. Is this something I should install (is it a FAST part?). Factory oil pressure sensor is long gone.Key on, engine off your fuel pump should have primed and you should be showing some fuel pressure. It says 0 above. FP correction is 80%. Does the fuel pressure ever show anything? It's possible you have fuel pressure, but the sensor, settings or wiring has issues. If you have 42 lbs. of pressure and the ECU is trying to add 80% injector pulse width, it will dump a ton of fuel in.
You could try just turning off fuel pressure correction.
Me as well, I don't really want to know, I just want the damn thing to start and run good enough to take it to someone who knows what they are doing with FAST. To have the car towed out of my garage is like the walk of shame for a gearhead.I am no expert. I have never set-up an XFI tune for anyone.......ever! But this seems to work for start-up for me and maybe me alone.
My car has 160lb injectors and a 90mm throttle body . And it starts with only the turn of a key. No foot work or double cranking is required. A very short rough transition takes place before it goes into a smooth high RPM idle. And then it idles down to a steady 1000 RPM at everything between 146 and 182 degrees. My base timing in the idle area is around 26 degrees. I have a little timing trim programmed to control idle torque because I have no accessories (no power steering, no AC, no idler pulley, no water pump) just an alternator. My cranking timing is only 18 degrees. As little as you can have it and still have the motor start smoothly.
I also have large crashes or climbs in my maps after 187 degrees. I simply do what I can to cause the motor to stall because I don't let the engine run if it gets hotter than that.
These are some of my settings below.
View attachment 331103View attachment 331105View attachment 331107View attachment 331109View attachment 331110View attachment 331111View attachment 331112View attachment 331113
Mike
