hemi8
Goin Sideways
- Jun 6, 2001
Stock with FAST adapter harness (Casper's box)Are you using a stock GN engine wiring harness with an FAST adapter harness? Or a FAST stand alone harness?
Mike
SignUp Now!Stock with FAST adapter harness (Casper's box)Are you using a stock GN engine wiring harness with an FAST adapter harness? Or a FAST stand alone harness?
Cal sent a new file. Since I found the coil pack was bad yesterday I have not reinstalled the plugs (which were drenched) and tried again, it may fire right up this time, only 1 of the 3 coils was firing which explains the flooding.Another idea. Did Cal send you a whole new file to try? Or are you working from some old file that's been modified multiple times? It might be worthwhile to start with a whole new tune file, maybe the old one is corrupt.
I'll be honest, if Cal has helped you and he couldn't find it, It's going to be a tough one to figure out. Or it's a problem unrelated to the efi.
I'll check this also before trying again.You don't need a fuel pressure sensor on the FAST. It was just one of the parameters on your dash (circled red below). Notice FP correction circled green. I'm not sure if that shows whether the fuel pressure correction is turned on or not, but you should check it. If you don't have the fuel pressure sensor, it should not be turned on. It's in the fuel settings if I remember correctly. (edit: found a pic online)
Congratulations!!!!!!!Added 2 bottles of Heet to the tank, new crank sensor & it started. Have to hold the throttle halfway open for it to run but it stayed running for the first time. So at least I have a starting point, now I can do something. FP correction was already off.
Mike
Not likely a FAST setting. Where (degrees) is you cam sync currently supposed to happen. You can datalog cam sync to see if the reading is erratic. If it is, you probably have a noise issue.Would this would be a FAST setting/adjustment and not another hardware failure?
Thanks Mike, I'll check it tonight.Not likely a FAST setting. Where (degrees) is you cam sync currently supposed to happen. You can datalog cam sync to see if the reading is erratic. If it is, you probably have a noise issue.
Also, double check your adapter harness. The ECU has two possible cam sync inputs, Inductive and Hall Effect. I assume you are using a stock cam sync, so you are using the hall effect input. In that case the Inductive input should be grounded.
So looking at the FAST ECU pin outs it looks like should connect wire A1 to A3?Not likely a FAST setting. Where (degrees) is you cam sync currently supposed to happen. You can datalog cam sync to see if the reading is erratic. If it is, you probably have a noise issue.
Yes, on the A1 to A3. I would bet that it's already done on the adapter harness, but check. You can get a better layout of the pins here. https://www.fuelairspark.com/pub/media/wysiwyg/FAST/FAST_PDF/XFI_Schematic_301100_GM_TPI.pdf The help file in the software has lots more notes about wiring, like grouding unused cam and crank inputs.So looking at the FAST ECU pin outs it looks like should connect wire A1 to A3?
If the cam sync is erratic how should I correct it, would I need to replace specific wiring with twisted shielded pairs?
Mike
Is that the Casper's coil tester?They make a spark tester that has a thumbscrew that's adjustable that you can load the coil to test it against the other coils, this is whatI use and it works like a champ
The one I have looks something like that
