I've been chasing a low O2 millivolts problem. I only get to work on my GN every month or so due to work and parenting so it may take me awhile to try different solutions.
I started noticing O2 counts in the 460-550 range at WOT with Turbo Tweak street chip ,50 lb injectors and a mild 12-25 lbs of boost. Fuel pressure would not go over 50 psi at wot. I installed 140 alternator,no change. Just finished installing new Racetronix fuel pump and fixed a bad connection to pump. It is hot wired. Now fp will rise to 58-60 lbs at wot but millivolts were only 464!!!! With 1.6 kr.
Tried to adjust fp and now it won't move off 46 at idle. Checked vacuum on fp regulator and it'll only go to 15 and starts dropping.
Is this my problem and where can I get a rebuild kit for it?
