A little weak out the back. Probably driving over the converter a little and need some more valve spring. Id expect 113mph out of it. You probably would have went 11.75-11.8 (at the same mph) if you had a 1.62-1.64 60'. The KR probably slowed it out the back too. Get the KR issue fixed and buy a wideband so you can see where you are. Throw a set of measured springs on there. 95 on the seat/280 over the nose.
You can order whatever springs you want. If you dont specify and get a specific build sheet with what you purchased you cant assume anything. I always check everything when i bolt an engine together. I dont need someone elses mistake to be my problem. To make it easier to understand for anyone reading this thread that may question it would you want to pay me or another person $100+/hr to diagnose and fix a problem that never should have been there in the first place? What if there was other engine damage because of it? Who eats that? I know im not.
