hotairgnx548
hotairgnx548
- Apr 7, 2010
Reciently put UMI rear upper and lower adjustable control arms on my hot air car. The car will not transfer weight and the 60 ft times suck. I removed the air bags. Today I pulled the car on a set of ramps and climbed under it (also have HRParts and stuff rear stablizer bar) the rear end housing is solid against the after market pinion snubber that I put on it 25 years ago. Pulled the snubber and shims out and what do you know I can bounce the rear end with my knee. Is there really any reason I need to get a stock snubber and put it on the car or is it ok to run it without one? See ya! John
