I know this is an old thread, but you guys seem to be studying something similar to what I am right now. I have a TH400 in a car and the the 9.5" PTC does not respond to stator or pump changes. I have been studying some things and trying to learn more about converter charge etc. I restricted the converter feed down to .125", and the cooler pressure is around 70psi, down from well over 100. But that made no change in the converters performance.
Last night I pulled the trans, and took the pump out and really studied how the fluid goes into and out of the converter and into the cooler. I found the hole in the stator support that leads the fluid to the cooler to be around 90% blocked because of a misalignment between the hole in the stator support and the hole in the pump. I started to drill the hole out, but though better of it and pulled another pump to look at.
I found it to be probably 75% blocked for the same reason. Is this normal? It appears to be a major restriction in getting the fluid out of the converter and into the cooler. Does this need to be addressed? I have no problems drilling it for experimental purposes, but I also don't want to do it if someone else already has with no or ill effects.
