bird
- Feb 20, 2003
following the advice from bruce (pts). i removed the valve body and voila! crack around the housing that supports the anchor pin for the band(see arrow). this should be the reason why my convertor went from a 3300-3400 stall to a 4500+. funny thing is the trans worked perfectly otherwise. has anyone else ever had this happen? even though this happened just after the trans brake install(stage right) bruce assured me it probably had nothing to do with it and the case must have just become fatigued.
once again thanks bruce for all your help. you really went out of your way for me.
richard
richard
