callmeebryan
- Jun 24, 2007
I had a question for those of you running the high volume oil pump on your 109's....
Is it absolutely necessary to enlarge the 4 main bearing holes, or are you guys having luck without doing that? I was reading GM high tech and they had an article that mentioned doing this.
Reason i ask is because i need to replace my oil pump and want to go with the high volume one for a little better oil pressure.
