SignUp Now!Norbs, I would find a way to decrease that oil pressure, or get ready for lots of oil leaks in your near future. 40 at hot idle is too much in my opinion. That's what I get when I cruise around on the street at 2500rpm. With your pressure, every time you want to drive your car, you have to let it warm up 10-15 min before driving it..........
norbs how did you calibrate the sensor??
norbs said:Seems I can;t get it the boost up, and oil psi down....everything works backwards for me........................![]()
Sounds like your car needs some Viagra...
What do you think your boost problem is from?
Converter to tight, wastegate stuck open??
AG
I would check for potential wastegate leak or if its stuck open for some reason. Maybe some welding slag or something holding it open.I really think its an excessive backpressure issue, I need to put a bung in to log it. I have the heavy spring in the gate now, I guess I have to add the 2nd spring next. Right now I have the boost duty cycle set to 0% I am trying to find Min boost..I'm still dialing in the VE table so the correction is still all over.
Why is the fuel pressure 78 when the boost is 5?
Allan G.
I will have a look at it today, does seem odd the spring I put in is at least 3x the pressure I took out, I wish I would have measured backpressure, then could see more what is going on..
Are you saying your backpressure is so high at 5 psi it is opening the WG? I find that very hard to believe. During spoolup the backpressure will climb a little while the wheel is being accelerated, but not that high. What turbo are you running, what size WG and what spring? You are the "king" of unique problems![]()
Maybe it's the 1.01 housing?
It could be the quickspool valve now has changed that 1.01 to .5 ish? Lets do some quick math. the gate has a surface area of 3.14 sq inches, so to hold back 1 psi we would need 3 psi spring, it felt about 25 psi force to push the gate spring in, if we had 8 psi backpressure at 5 psi boost, I would seem about right. I put the 2 springs in , I needed help from a neighbour to install it or I would have never got it together, unless I would have to use my foot and stand on top of it. I could not see any evidence of the valve leaking on the seat.
How is the plumbing to your wastegate set up? What sort of boost control system are you using?
