Norbs, you forgot to mention the injector issues.
My opinion: You can't blame FAST for not telling Norbs about putting in pull up resistors. This is a custom deal where we are using sensors in ways they weren't designed to be used. I found this problem years ago with the Classic Fast and had it incorporated into the dead head connector that I asked Casper to make for me. Norbs didn't purchase one of these. FAST doesn't have any experience in this area.
I assume tech support is one of the main reasons you bought the system from me, Brandon. I have quite a few customers without a pull up resistor on the cam sensor. Just log the "Cam Sync BTDC" and if it appears stable, you're good to go.
I'd like to see what Cal has to say about needing a pull up resistor in the system for it to work. I can see from the video you have there that the signal is more squared off. Let us know if you switch back install the resistors and everything still works. I was having an issue with my resistors so I only have one on my crank signal for now.
Brandon.
