I do have DIS checked and I did move it to to 5 degrees and the timing stead of being above 23 degrees out it went to 17-18, but when you rev it up it still retards at least an additional 15 degrees or more, headers were glowing i had to stop.
SignUp Now!DIS is just the ignition strategy. It won't be using the bypass or EST wires. Your timing will be controlled by the XFI via the points wire to the ignition box. I assume you have the steadfast box disconnected and the MSD doesn't have any timing retards activated.
And some of you think the Electromotive system is less user friendly than the FAST system? Holy cow. What a nightmare.
Is the Caspers Adapter box being used in this application?
Thanks, but I found someone closer, If its not the box its some wiring problem, I have yet to find.Norbs If you want to swing out one night this week our this weekend. Bring your box and I'll plug it in my car and check it with the timing light, if you can't find someone closer that will help you out. I'm about an hour away. You can check out the coil on plug setup too and maybe you'll wanna switch.
Brandon.
Brandon.
Did you swap the the red and green wires?The CCCI dead end connector is not being used, but the caspers adapter box yes is used.
I think Norbs is using a HE cam signal. If so, he won't need to swap the wires. Either way, I suggested for him to leave the cam sensor unplugged until he gets things sorted out
Norbs, is a guy who likes to do his own things in his own way.
