Now I'll put the angle into the long walls by hand, then I'll mount the flanges in the mill again and bring the rest of the port walls to their final sizes. The taper will then be put in by hand.
Hah! I know what you mean. What did I get myself into?Leave yourself some room to do the final port match after all welding and final flange to head machining are finished. When you set up to weld the final assembly together , set it up so that the ports are all higher than the ports in the heads. The manifold will warp quite a bit and this will allow you to mill the flanges to an exact fit to the heads. Love your post here ,and wish I still had your energy and time!!! Mike
Less than 8000 rpm to run 7's.Squid4life said:What RPM have most of the fastest SII V6 guys turned normally?
It'll be over 8,000 being destroked and with fewer cubes. I'm figuring around 8,700. At about the natural frequency of the present driveshaft.Less than 8000 rpm to run 7's.
Alky V6 said:It'll be over 8,000 being destroked and with fewer cubes. I'm figuring around 8,700. About the natural frequency of the present driveshaft.![]()
Agreed. I'm going to wait and see what the car wants. If traction becomes an issue, even on a good track, then I'll be doing some major chassis work, which will most likely mean a different driveshaft dimension. Only want to buy a driveshaft like that once.At least the driveshaft speed is more relative to mph at the top of 3rd. If you need it it will be a relatively cheap investment at this point.
I have an interesting problem with the runners. The sim is showing that an intake runner length of 2.0" would work extremely well for peak hp, sacrificing a little low end.
The stack up looks like this. The intake flanges are already 3/4" thick. The plenum wall thickness will be 1/8" thick, and the runner entrance plate with its radiused entrance will be 1/2" thick. That leaves the runners being 5/8" thick?
The runners themselves are going to be very short suckers. This is going to be interesting.
I think the bolts will be going clear through the complete stack up, just like the Stage I manifold.
And, I still have to mount per runner, 2 electronic injectors, one mechanical nozzle, one nitrous nozzle, and one cold start priming nozzle.What a cluster fandango. This is going to take some creative imagination.
I've tried different lengths. As soon as I add just one inch, peak hp begins to drop. Especially with that first one inch. Almost a 100 hp drop.Mechanical injector and Nitrous nozzle could probably run in the interior ?
I am also surprised at the 2" runner length. Using the simulator, I would think that you can reach another more optimum length for fabrication.
Looking at big inch super stock Hemis making about 1000 HP normally asperated, they have very long runners that cross over each other to take advantage of manifold tunning. Since you are big on this concept, I would think that there would be several lengths that could be used that would yield the same results.
Allan G.
For sure, the mechanical nozzles will be interior. Primers will be mounted to the roof of the plenum.
