I figured the same thing. The shafts being so large with the T&D, and the fact that they're solid 8620 material, and the amount of roller bearing contact would have to be a plus. Larger shafts and larger diameter roller bearing assemblies will always equal more load bearing capacity. That's exactly why people tend to go with larger body diameters with lifters. Larger pins, needle bearings and rollers can be fitted for better load bearing.The T&D will take any thing you can throw at them. We have used them for years with very high spring PSI and never had A problem.
