SignUp Now!Cal why don;t you convince Donnie to go XFI, it would be so much easier to tune??
Maybe it would be easier for you. Having already worked with the TEC system, it's a piece of cake for me. I don't understand why you feel it's so difficult.Cal why don;t you convince Donnie to go XFI, it would be so much easier to tune??
I thought you'd be grateful that I gave you guys a chance to catch up.Don't rush on my part. I'm anxious to see what kind of ET you throw down when she's back together. Although, the longer you take the faster everyone else is getting. It's a good thing you and Tony never locked anything up.
Just because a system has a bunch of gadgets doesn't mean you have to use every gadget.Well timed based nitrous control, different A/f targets using NOS, fueling, timing retards, wideband o2, etc., 24 sensors of data logging..3 rpm limiters.etc
What gadget do you feel I will not be able to get by without?
In Norbs's case...you HAVE to use all the gadgets.
Traction control will be added.You are correct, and loving it.. For your setup Donnie I would say the traction control and the wideband with +-25% correction would be the key features you need.
Tuning of the intake runners is separate from the plenum volume, unless you're attempting to use the plenum volume to enhance your pressure pulse tuning.I see the increase in plenum volume, but how does it play into the role of long vs. short runner lengths. This tosses that theory out the window doesn't it. I was wondering about the difference between the carb vs. the tunnel ram ( short vs. long runners) and was pretty much talked out of using the tunnel ram for the sake of torque. Keep up the good work.
