turbobooster
- Nov 12, 2002
alright guys im somewat ready to begin the build just need experienced help i have a new ta33c and 36lbs in my possession i dont have my hot wire and 340 pump yet and i dont have an adj fpr either i have a few questions before doing anything first i know i should do one thing at a time so i dont run into any problems or confusion should i swap out the injectors now or will that give me running issues? or should i wait till i get the hot wire and pump ? even if i do wait wat is the best starting point as to wat goes in first? i hope im making sense my other thing is the chipping aspect of this should i do the 86/87 ecm conversion before i upgrade mods or can that wait? and get my chip at the final once everything is in ? now that im getting closer to wat i want its a bit confusing as to wat to go with first maybe u guys can tell me how u went about it wat did u do first second and so on... thanx
as far as mods already on my car i have a 3 inch mease dp cold air intake adj wastegate the rest all stock
