T the wrath Active Member Joined Sep 29, 2002 Sep 11, 2017 #1 I wanted to know is there an alternative to the heavy pin that these use.
B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Sep 11, 2017 #2 Call up Trend and order whatever you want. You will be drilling the crank if you use the same % during balancing Sent from my iPhone using Tapatalk
G getdowngranny Mr. Fix It Joined Jan 8, 2006 Sep 11, 2017 #4 the wrath said: What is trend? Click to expand... Trend is a company that makes quality parts including wrist pins. Sent from my iPhone using Tapatalk
G getdowngranny Mr. Fix It Joined Jan 8, 2006 Sep 11, 2017 #5 the wrath said: I wanted to know is there an alternative to the heavy pin that these use. Click to expand... I used these JE pins. https://m.summitracing.com/parts/JEP-94027501651S Sent from my iPhone using Tapatalk
E earlbrown runs with scissors Joined May 26, 2001 Sep 21, 2017 #6 10 years ago I bought a set of Sealed Power forgings for my 3.8 and it came with the 'light pins'.
T the wrath Active Member Joined Sep 29, 2002 Sep 21, 2017 #7 Earl brown speed pro doesn't sell the pins separate. The Pistons I have don't have the coating on the side like yours. Do you have a suggestion before I pull the trigger on the je pins?
G getdowngranny Mr. Fix It Joined Jan 8, 2006 Sep 22, 2017 #8 the wrath said: Earl brown speed pro doesn't sell the pins separate. The Pistons I have don't have the coating on the side like yours. Do you have a suggestion before I pull the trigger on the je pins? Click to expand... My pistons are the same as yours. No coating on the skirts. The only other pins I found that would fit are Trend pins that full throttle carries. Sent from my iPhone using Tapatalk
E earlbrown runs with scissors Joined May 26, 2001 Sep 25, 2017 #9 the wrath said: Earl brown speed pro doesn't sell the pins separate. The Pistons I have don't have the coating on the side like yours. Do you have a suggestion before I pull the trigger on the je pins? Click to expand... Do your slugs have the pins with the small ID like on gnttype.org? I've never seen those in real life. Every set of TRW/FM/Speed Pro slugs I've seen have the pins like on my picture.
