getdowngranny
Mr. Fix It
- Jan 8, 2006
Ok. So, I will be hitting the track next weekend and want to turn it up a bit. I know how to do but need some advice. My sig explains my mods. I have a TT alky chip and 60lbs injectors. I want to safely turn it up at the track. I am currently running the chip as it came at 25 psi and alky knob at 5 with zero knock. Should I leave the chip alone and come up on boost and alky or should I raise the timing and fuel in the chip? If I add 1-2 degrees across the board, how much fuel should I add across the board to compensate for the timing but still taking advantage of the timing increase? The car runs strong and clean as is but I want to take it a bit further. Any recepies would be greatly appreciated.
