Up Pipe question...
1LowLeSabre
Can you make an up pipe out of anything that's the same size, shape and diameter? Could you use copper?
I wouldn't use copper because of vibration, and it would be freeking expensive to boot.
Copper, Stainless, PVC, aluminum, steel, brass, reinforced rubber hose, radiator hose, titianium, un-obtainium (we use ALOT of that on aircraft;) , but that's why we are so far behind), inconel, carbon fiber, kevlar, fibergalss, or just about anything that will withstand 60psi. Intercooler plumbing is pretty low pressure and tempurature requirments. A polished copper up pipe might look real cool, especially if you have to sweat all the joints. Hey it might even work for a down pipe if it is thick enough. There are some guys running aluminum down pipes in drag cars. 7 seconds of 1700* won't melt a aluminum pipe especially if it's coated. Post a picture if you make it.:)
