I have a question that will go a little off base here - please do not yell at me...
I just ran my car at Reynolds and it ran like crap. I had been battling a lean problem for a few weeks and thought my NB O2 sensor may have been causing it and replaced it with a Denso. I am dumping alcohol into my pipe to barely keep at 11.2. My car was breaking up on the upper end and losing power. I put a gauge in visable range during a run, and I had 58 lbs of fuel pressure and I should be at 24 lbs boost, but my boost gauge is fluttering like crazy.
I have a recently installed Greddy Spec II controller that worked solid a few weeks ago. Looking at my powerlogger run, my boost (from the MAP - correct?) was pretty solid across without fluctuations like what I saw on my manual gauge. Could the possibility of having to spray soo much alcohol to keep from being lean from a defective pump be my problem and cause a power loss? My duty cycle was like 90. I am going to post a help thread to inquire about this.
I was going to try replacing my fuel pump - but it is an unopened from FTS of these pumps and I dared not to.
Thanks in advance...
Mike
I hope that your head gaskets are ok. My car was doing the exact same thing and i got a headgasket
