Well, two days ago i developed a vibration in my car, that turned to slight knocking noise and heavier vibration. Took the pan off, found 2nd to last main bearing burnt and shaved. FML.
When i purchased the car, the previous owner said the crank was cut and new bearings were in, New timing chain and lifters and oil pump. I have pulled the heads and done springs, valve job, gaskets and bolts since i had it. Motor has about 3000 miles on it since the bottom end was done.
Few questions: Crank is .010, can these cranks be machined further? I think the main is beyond a polish at this point.
With the mods i have (check sig), should i do a full tear down and replace pistons, rings, Oil pump, rods and crank? Along with maybe a small cam and head porting? The machine shop guy i use said he is good at fixing the oil flow problem these motors have. I would assume this was the cause of the bearing failure. . . i have not beaten the car to death and im running 18 psi with alky tuned with no knock and good a/fs.
Any suggestions on upgraded bottom end stuff, or should i just recondition the stock stuff for my power level? I plan on running 22 psi.
Would it be a waste of time to just pull the crank and have it fixed and put new bearings in, and just flushing the motor out? Cost is a factor, i spent alot already and my budget is reasonable for the rebuild but not crazy.
Sorry for all the questions, any help would be awesome. Thanks guys
