chasmat2316
- Nov 7, 2006
I'm looking to up grade the ft brakes on my GN still using powermaster, what are most doing?
SignUp Now!skip the drilled rotors - all drilling does is decrease the mass of the rotor- and thus, the amount of heat it can absorb- and create a bunch of stress risers where cracks can start.
the C4/C5 (84-05) Vette and LS1 (98-02) Camaro 12" and 13" brakes can be made to bolt up with a little fabrication for about $500
I've had the Aerospace kit for years now and dig it, hard to beat at $700 for the fronts while saving off a lot of weight ( 23lbs total ).
Stock spindle, needs to have 2 holes tapped and then sawsaw off a part of the spindle ( so pretty much you ain't going back ).
You need to run a 1/2" spacer with the kit due to the caliper etc. Most guys running stock rims and even 235's etc won't need to worry. Guys like me with 265/50's, well that took a few calls to Summit for some new Centerlines ( 5" B.S. ).
That was mfg'd by GMC,CRUZN...i can not see a motor home useing metric calipers,,to small ,i believe you are useing a type of police pack,, station wagon ,, big calipers
