where is the best spot to buy weather stripping?
hemi
im thinking of going with steele products, thats the company my brother uses on all the cars he restores, just trying to see what the buick guys say and feed back from any where im not buying soft seal.
weatherstrip
I myself have just started to install the steele brand door seals so far so good the roof rails are my upcomeing x-mas present. Its hard to beat them they offer a 100% money back gaurantee if your not satisfied plus they are very affordable compared to oem.how do you not give em a try! Good luck with your choice.
weatherstrip
Well i will be sending mine back to steele since the holes dont line up and there is no plastic molded into the rubber for support like the gm ones, so i learned my lesson i tried to save a little and got bit so i will be spending the money for the gm ones.:smile:
Metro is the best aftermarket weather strip. Damn close to GM.
Steele and SoffSeal are JUNK.
Get Metro super soft from Summit. You'll be hard pressed to find it cheaper anywhere else.
If money was not an issue or you wanted to replace them in stages, I would go with GM. For me, I used Metro and it worked out well. No matter which way you go, take your time and adjust, then re-adjust, then adjust again to get the window fitment right.
