’87 Ltd. 39K miles. No speed parts. Replaced vac lines, plugs, ignition module, coil pack, IAC, trans & diff fluid, oil, waste gate, fuel filter & O2 sensor. Added Gen2 pump, hotwire, Scanmasetr, boost gauge, LT1 MAF & translator, TT chip for 91 with stock injectors. Car runs great. Just doesn’t have any real zip in the low end. It pulls okay once it gets going, and the boost gauge reads 15-16 lbs. Do a launch with brakes on & 4lbs. boost & the tires break loose for maybe 5 feet and then nothing. Acceleration is kinda “poochy”. Definitely not a tire-shredder. I don’t expect it to be a rocket ship, but something isn’t right. What to check? If there was an exhaust leak would it still be able to make 15 lbs. boost? Thanks.
