big reazon
- Nov 12, 2006
WHat do you guys run for front springs as far as drag racing. I know the v8 guys run the moog 5596 v6 springs to help with weight transfer. But What do the turbo 6 guys run as far as hooking up?
SignUp Now!5596 spring here with 3/8 coil cut off. You're going to need a good shock to control the energy of the spring.
Billy T.
gnxtc2@aol.com
I know I might sound silly to ask this...but are they a big (or small) improvement over the original factory installed springs and worth changing? Also, how do they affect handling in normal street driving conditions?
Claude. :redface:
Ok, I'll be more specific...Right now in the front, I have stock springs with the only mod being some Lakewood 90/10 shocks. At the rear, I have some H&R upper and Wolfe racecraft lower control arms, an H&R sway bar (which I have mixed feelings about it ), some aftermarket springs (because my stock ones were sagging too much) and QA1, 12 position adjustable shocks. But ever since the late Eric Shertz (from Dynotech) installed an H&R sway bar on my car which was supposed to help my car leave straight, it never left the line hard anymore, pulling the front wheels off the ground again like it did before. I'm getting some 60 ft. times around 1.49 and my best run so far is in my signature below. I don't know what I'd give to have the car leave the line hard with both wheels up in the air like I often notice with cars running... slower than mine! ...a little frustrating! :redface:
Charlie, I've had Jack Cotton replace the springs for me because like I said in my previous post, the factory springs were sagged too much and were causing the tires to rub against the fender lip mouldings, but these were springs that Jack had in stock and don't know what they are...What springs are in the rear Claude?
Thanks for the link!...:wink: But, are the springs a direct replacement for the stock ones?...If yes, why are they calling them "coil-over"?...Over what?You can run QA1 coil over springs in the stock location in the back.
QA1 Precision Products 12-150 - QA1 Coil Springs - Overview - SummitRacing.com (I am not saying this is the right PN
Dusty Bradford gave me the part numbers, they were like $38 ea from summit...
I will see if I can find the PN, if not send Dusty a PM.
If the coils are narrow and then wide you have cargo coils in the back and that's part of your problem. Cargo coils hurt on weight transfer.
Hi Joel...I am running some Phoenix 10.5"x28.5" tires, and leave with someting close to 10 psi at the line, off the trans brake. The car usually goes straight unless the rear tires get out of the "groove" which happened a few times so I lifted the foot on these occasions.:frown: My front suspension is 100% stock except for some 90/10 Lakewood shocks (which by the way, came off Eric's car!) :wink:. At the rear, I have some H&R adjustable upper control arms and some Wolfe Racecraft adjustable lower ones, along with an H&R sway bar (which I've always been disappointed with) , and finally some rear coil; springs which look like cargo coils (with coils spaced unevenly).Claude, how are u leaving the line.... I mean at wut boost, off the trans brake? Wut tires are u running?...is the car going straight when u leave? Do u still have ur front swaybar connected? Wuts ur front suspension consist of....I havent seen under ur car in awhile so i cant remeber... I mean 1.4s 60fts aren't that bad.....are u spinning off the line? Honestly, would u rather be wasting power with a huge wheelie or getting down the track faster? Jus sayin...... Joel
