WE4 WARRIOR
- Mar 5, 2006
getting caught up on 1000 hp mark for a street car. can this be done with a 109 block. are there any out there. what does a 1000 hp buick do in the quarter.
Not quite. Maybe that much at the flywheel not at the wheels though. Probably closer to 825hp at the wheels.Well, a TSM car weighing 3550 lbs. going 9.0 in the 1/4 makes approx. 960 rwhp
Very few on here have a chassis that will handle over 1000hp. Too be very honest most havent even been in a car that makes 500+ to the wheels. The nickel content isnt the problem. The problem is when your trying to make 200hp per hole on a casting that was never intended to be over 400hp total. The block is a lightlweight with poor main stability. The stage 2 is a lot heavier in the areas in needs to be and has a much more rigid webbing area and extra fasteners to keep it all together.No way will it hold up, their is just simpley not enough meat in those blocks to hold that kind of power. They are low nickle content, thin wall castings. It is my opinion that alot of the crank bearing problems you guy exsperiance are due to block flex. Girdles help keep the caps from walking to some degree, but do very little for torsional flex. I race Pontiacs and they have the same problem with the stock blocks, I now run an aftermarket IAII block which is they same block dimensionally but weighs 60 lbs. more, with a high nickle content. I am pushing 1038 to the rear wheels with that block, and it is capable of handling 2000 HP. It would be benificial to the Buick crowd if a good aftermarket block could be offered at a competitive price along the lines of the Indian Adventures block that is offered for the Pontiacs. You guys could really turn the wick up then.
At 3550 and 143-144 mph ur car would be making about 810-825 to the wheels. That's not near fast enough for a 9.0 pass.Not quite. Maybe that much at the flywheel not at the wheels though. Probably closer to 825hp at the wheels.
buddy of mine has a 109 with a stock crank ,girdle, definetly making 925+rwhp... it traps 140+mph so its definetly over 900 hp and is full interior/ a/c car WITHOUT rollcage that also see's the street sometimes.... just gotta know what you got and be smart about it. Don Cruz down here in florida had a 8 sec 109 with a **** load of internal work before he pulled it out for a stg. 2
We put down a little over 800hp to the tire on Don's 9.0 TSM combination. Both he and Fiscus put down 1053hp (think the dyno may be maxed) at Richard Clark's dyno last week with TSO combo's.
