Finally got around to bolting on a TA60 W/6.1 TT Chip. I did not get much chance to tweak anything Very crowded at ATCO 9/12/14.
I was only able to get 3 runs. Last run was at 11:45pm There a couple of oil downs at the track. I tried to make my usual launch 5# on the first pass. Just spun the tires 12.8 @112.81 Then tried 0# 11.55 @114.23 Then 2# 11.48 @114.57. I had to Max the Alky at 8 still had a little KR top of 2nd gear then bottom of 3rd.
UPDATE:
86 GN 71K
11.48 114.57mph
60'- 1.584
Bst- 28.5ish#
Launch- 2# (Foot Brake) spins with anymore
Alky- 8
93/Alky
Chip- TT6.1
Stock Long Block (New 980 comp springs), Stock MAF, Stock Rear, Stock suspension, 275/60-15 ET streets, 3650lbs W/driver, Dutt neck Stock IC, Closed Ex (Pypes), 3.5 DP, L/U converter 9.5 Protorque Not Locked, Homemade Grainger Bst control, Power Plate, 60# inj, Razor Alky, 1 Air Bag, LC-1 WB.
Thanks, Mike
