1st time track run
xrunner123
Hi.
1st time at the track 30 years.
1nd run 11.9, 2rd run 11.6 @118mph. ~2.0 60ft time.
Here is a picture of the log.
Is the 02mV normal to drop somewhat?
Does the o2mv coincide with the wideband?
There is some boost creep and I see that fuel is being added but why does the 02mv start to drop?
I also attached the PL log file if anyone wants to comment or give thoughts.
Thanks,
I would like to see what the fuel pressure was during the run . That little bit of knock just before you let off could mean it needs more fuel . Set the AFR to 10.6 and log fuel pressure . Voltage is a little low also .
FP is logged in the pl file. Analog 4 pressure 100psi setting.
AFR is set to 10.8.
Thank you for the response.
Also I'm not familiar with alky and how it effects O2's @ WOT , I run E85 . Mr Spool could answer that .
What were the air temps at the track? I always had to richen it at the track on cool days.
It was 50 to 55F.
Wide band on pl showed 10.7 to 10.8 the whole run. I never tuned with nb so I don't know what it should look like.
Your 60 foot is sucking cuz you left at 2775. Next time put it in 3rd gear...not OD. Put a new Denso 02 sensor in it.
Eric has aggressive mode for his chips...read up on it. Just bump the low gear timing 1 degree and it engages.
I didn't notice his 2.0 60ft , He should be able to do much better with Dave's converter in there . Seat time !!!!!
And line lock if it hasn't got it...and low gear tuning. With Erics default timing/fueling with my chip I could get out and run faster. RPM's look like they might be struggling in 3rd as well.
Yeh. I goofed on this run and left in in OD.
And yes 60 foot times suck because I could not hold any more than 1 or 2 lbs of boost.
I did read about this and I bumped the timing up 2 deg to get it out of some mode he calls it.
Typically you have to flash the convertor to about 3500 on the launch to get into the high 1.6's. 4,000 to hit the 1.5's.
You need to hit the tires hard to get a good 60'. 2psi isn't going to cut it. You'll need to address your brakes if you want better times.
