SignUp Now!Entertaining thread, isn't it?I better get a big box of popcorn if this keeps going.
I'm not sure. I'm still learning the chassis side of it.Why do you have tire slip on the 1-2 shift? It the trans hitting too hard in the gear change and upsetting the chassis causing problems in second?
There are more parameters. A total of 37. These are just the parameters I called up for display. If I displayed them all at once, it would be a garbled mess.It is kind of difficult to read, but here's my observations:
It appears to be starting the pass pegged rich, then going real, real lean at the big end. So lean, that it is actually causing the car to miss as it reaches 33psi. The rpm log looks absolutly terrible.
I did some research on the system you are running and it looks like it has the ability to log analog sensors. It also looks like you would be able to use another input for a transbrake flag. Since this doesn't cost anything and also gives you more information, I am suprised you aren't logging more parameters
Thanks for posting
Not a tuning guide. The name of that thread was me being sarcastic. I knew nothing about that unit when I started that thread. Let's not forget, I'm not a teacher here. Most threads I start are just my way of thinking out loud, sharing my experiences and logging progress or disaster. If people pick up something that is useful to them, then great. It was worthwhile then.You are going about reviewing the logs correctly. I don't think you will really be able to get the chasis sorted out with the limited information you have. After seeing the boost in the log, I looked up your boost controller settings and don't think you are really using all those stages the way you might think you are. Also, I could be wrong since I didn't plug the actual values into a controller, but after a quick review it appears a couple of target boost setting may not be attainable. I may be mistaken and I'm sure you wil let me know if I amActually, I am suprised you have such an in depth tuning guide to the controller without more information to guide your settings.
I would like to take a TV timeout to thank our sponsors:biggrin:
Also please be sure to check out the google ads on the page to help support the board
Now back on topic...
I understand what you mean by some of the boost targets in my controller settings maybe not being obtainable.(snip)I would plug the numbers in and check the curve out first. I too look at the table and don't see how it comes up with the curve it does.
Just one point.
Even though the engine was massively leaned out on the top end, and lean surging, look at the MAP. Holy cow! The turbo was saying, "Come on you *****. Let's go!" No drop in MAP during that kind of condition?!!!
I think this engine will be very capable of pushing the boost with this turbo to, let me put it this way, very interesting levels.
To add to the above. When you look at some of my customer logs, the rpm line will seem very flat like the engine isn't accelerating. To the untrained eye you would think the converter is slowing the car down because it's not gaining rpm.
But if you have enough data logging equipment, you will see that the converter is holding the engine in it's usable power range as the converter continually couples. This puts more power to the tires without dropping the engine out of it's power range.
I was actually talking about not being able to reach the Target CO2 levels you are programming in the AMS. It appears you are not giving enough time in some stages for the ramp to actually acheive the target.
