turbonut85
Rarely used member
- Apr 11, 2008
Ok guys, I had to pull the intake on my H/A 85 GN...don't ask.
But now I have the problem solved. So I have the stock intake off, and my heads are very MILDLY ported. ie: they smoothed the ports where they meet the intake. The intake has not been touched. What kind of benifits would I see if I port matched the intake?? Jerryl, Brad, 231---chime in here.
Here is my setup:
Stock block bored .30 over
froged speed pro pistons
212-212 comp roller cam/lifters
new stock turbo
42.5# inj
Turbo Tweak chip
87 ECM/MAF
stock air box
adj regulator
hot wired walbro pump
Stock up/down pipe
2-1/2 stainless cat back
hi flow converter
Here is my setup:
new stock turbo
42.5# inj
Turbo Tweak chip
87 ECM/MAF
stock air box
adj regulator
Stock up/down pipe
hi flow converter
