Dusty Bradford
- May 24, 2001
Don, nitrous is fine if your just playing. We used it back in the day for street racing. You didn't have worry about someone leaving on you because you weren't ready. Since then, converters and knowledge have come a long way and besides that, nitrous is not allowed with turbo's in the majority of heads up classes. Import classes allow it because it's the only way to spool a large turbo with very small ci. I wouldn't call it cutting edge technology. I'd call it a crutch being limited to small ci. If the imports weren't allowed to use nitrous they would still be stuck without boost until 300 feet out, or slow et's.
In my racing class, ci is limited to 650ci. Why build a 302ci turbo motor to make 2000hp when you can build a 400ci? It makes no sense. A lot of guys over turbo their combination just to say I have XX size turbo on it. Nitrous is also a crutch used to make a combo work that is not optimized. If a guy has a 231ci with an 88mm on it and wants to shift at 6k, the converter is not the problem, it's the chosen combo.
The only thing making converter companies rich is people who pay 3k for a bolt together converter.
