SignUp Now!Late model s10 blazer fronts will work and give you bigger brakes without having to change your suspension. Also came on the extreem models. multiple caliper pistons and an 11" rotor.
why not use the B-car spindles and get 12" 1LE rotors! You will need to switch to Hotchkis upper arms but you will get a better camber curve in the process.
Conrad C.
better yet- why not just use the 1LE rotors and 2 piston PBR calipers on your stock spindles? i forget what specific combo of inner and outer bearings you use, but the rotor is a bolt on, and the caliper can be made to fit with a little fabrication.why not use the B-car spindles and get 12" 1LE rotors! You will need to switch to Hotchkis upper arms but you will get a better camber curve in the process.
Conrad C.
