nailheadpowered
- Oct 31, 2004
I over boosted my car and blew the head gaskets i have removed heads etc. and i drained my oil about an hour ago and found it with anti-freeze. question car was not run with this down below as my oil was not a milk shake but two seperate liquids one being anit-freeze which came out first when i removed the drain plug and then the oil, my question as i have read that the bearings will not be any good if anti-freeze gets below is that is this true? do i need to consider replacing my crank and rod bearings or should i be able to put new oil in run for a couple of minutes then change oil to new oil through the motor etc. thanks for the input.
