22lbChevelle
 - Jan 14, 2005
You can barely see it in this pic, but it turns out that the mounting bolt spacing on the top side of the LS2 coil bracket is the same as the valve cover spacing. I just used valve cover bolts with the studs on them to mount the coils with hardly any modification. The coil brackets were from a 2005 truck if I recall correctly. If anyone interested I could take more detailed pictures.
