pacecarta said:i would assume the gray is for the timing retard enable on the two step
oring is probably for birth control
Up yours doc lol
SignUp Now!pacecarta said:i would assume the gray is for the timing retard enable on the two step
cool, I had not tried to run it from the caspers "thingy".
Careful or you will melt the spark adapters.
Bob
definitely well worth the wait, i can tell its idling on all 6 now lol. The only thing is that it looks a little bulky under the hood the way it sits, im thinking of making a bracket and bolting it to the firewall in a lower position.
even being able to move the module to the driver fender well would be better than its current location. and also make access for dip changes so much easier
caspers would be a good source for the ccci extender, I can help with the coil-pack harness extension. When you get an idea of where/how you want to mount everything, let me know the length of the extension you need.
Bob
