Just put my TR-6 on today. My impression is very positive. Idle is smoother, throttle response is better and the car does feel stronger.
I believe I'm the first Hotair with the TR-6.
Here are a few things other hotair owners need to know if considering this module.
1) You'll need the Casper Electronics 84/85 to 86/87 ignition module adapter plate if you don't already have one.
2) The Casper Electronics 84/85 to 86/87 ignition conversion harness with hotwire.
3) 4 additional bolts for the bottom of the TR-6 ignition module. This allows the module to sit high enough to clear the upper radiator hose holder on the mounting bracket.
The only problem I see is knowing if there are any trouble codes. It's not a 84/85 problem, it's a digital dash issue since there's not a tach to show the codes.
Very pleased with the results so far. Thanks Bob
