Bob Bailey ignition module
take a pic with the module connected so we can get a better idea of how it looks!
the red ones are Magnecor. I get them custom made to my specs.
Bob
the coilpack is from a 2008 Silverado V6/2wd. I get them from Delco.
Magnecor's "good" wires are all red. I can get them in 8mm "standard" in blue, and 7mm in black.
Just noticed something that I forgot to put in the manual.
The CCCI fuse needs to be "up-sized". This ignition system packs a lot more punch over stock, especially at high RPM. So it draws a bit more juice....
So, change the CCCI fuse to 25A.
Note, if you do blow the CCCI fuse, the unit will blink a trouble-code "18" on the tach for you.
Bob
Bob
thanks bob, ill take the one from the a/c
Bob
sweet
Bob
Does this need to be done even if the CCCI is already hotwired?
