GNONYX
- Oct 16, 2009
Also keep in mind to disconnect the orange wire behind the battery to rest the code it gave you before.
SignUp Now!Nope, no bad smell or melting . what could I use to keep the coil cool?
How are testing the replacement knock sensor?
Did you already replace the factory MAF with a new factory type or a LT1 sensor and added a translator since it gave you a code 34?
Did you replace the O2 sensor since it gave you a code 13?
What are the Scanmaster readings before replacing these parts and after replacing with new MAF set up?
OK, I disconnected the o2..... Started it....the car ran it had that lil hiccup idle that it has when it sputters.... Drove a few blocks w/ a bad sputter and code 13 and in open loop that turned on @ about 1/8 mile turn around parked it .... Cut it off .... Started..... It ran perfect around the neighborhood...... Parked it ..... The o2 is still disconnected.......where do I go from here?the LED blinks to indicate open loop mode.
unplug your O2 sensor, reset your ECM, and go for a drive. Report back.
Bob
It never showed knock ....ever. thats why i got a wrench and tapped on the block ....it only shows the knock when in open loop . When it goes to close Loop I can tap on the block and the scanmaster doesn't show any knock. Can the ESC sensor cause this?Cecil, just to be clear here is the instructions for the Scanmaster http://turbotweak.com/scanmasterinstructions.pdf As you see in the intructions, knock shows on the right part of the Scanmaster in "retard degrees". The worse the knock, the more degrees of timing is pulled. That is what is showing, degrees pulled from timing. The higher the number the worse the knock. It should stay 0.0 at start up and driving with no boost, cold and warm. If the tune is good ie; enough octane, enough volume of gas, correct timing there should be no timing retarded drivng around with no boost and then in boost. So how many degrees of timing retard is showing when you start the engine cold? When it starts to sputter does it show any retard or does it go to 0.0? If it's warm when you start it does it show retard?
