Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
Ok. What your telling us is you are causing knock by tapping the block. It is not just showing knock on the Scanmaster on it's own. Now that is cleared up. So if cold in open loop you can force knock but if warm in closed loop you can't force knock by tapping on the block? Sounds like when it goes to closed loop it's not getting the correct signal from some of the sensors.
