SignUp Now!How many miles on it outta curiosity
149-150k. It was stock till about 143k. I beat the balls off it for the last 2 years and only paid $550 for it. It was over 600hp the whole time i had it. I can only speculate on what caused it. I had a power plate on it and heard from others it may be lean on #1 with the plate installed using alky. I ran at least 110 octane and methanol the whole time.
Sucks, but isn't your new motor almost done?
just weld up the piston and turn the boost back up. lol
Lol. I want to have the block magged to see if its cracked in the mains. Ill pull the pan off and check the condition of the bearings soon.
Seen cracked pistons from high RPM's. How high were you spinning it? Interested as I'm a stock bottom end guy myself.![]()
5900 regularly. It hit 6400 a few times![]()
...heard from others it may be lean on #1 with the plate installed using alky.
post up more pics when you tear it down...
