SignUp Now!I wonder if it was cuased by excessive cly. pressure from running 30+ PSI and knowing you most likely alot of timing also![]()
How did this happen, on the street, track? Did it go into detonation for some reason?
I'd love to see the underside of the piston to see what it looks like and see where the crack starts. Last one I saw had stress cracks where the wrist pin goes in the piston from what appeared to be over revving a stock unbalanced engine with heavy pistons. You my friend made our crack look mighty wimpy by comparison.![]()
What do you mean?
It was only totally cracked through the side in the pic i posted in post #27. The other side it stopped before it passed through the oil rings. It could be hairline all the way through though.I'd love to see the underside of the piston to see what it looks like and see where the crack starts. Last one I saw had stress cracks where the wrist pin goes in the piston from what appeared to be over revving a stock unbalanced engine with heavy pistons. You my friend made our crack look mighty wimpy by comparison.![]()
Im referring to the RJC powerplate. I have heard but not confirmed that it may cause a lean condition on #1 with alky. I have not tested egt's on individual cylinders to be able to prove any of this though.
Yeah that would suck I have a PP on my ride.
There was no evidence of lean out here. No damage to the piston other than the crack. If it was lean it would melt the piston and there would have been aluminum splattered all over the combustion chamber. I ran 10.6-10.8 a/f and had no more than 3% correction at any time.
What is very interesting is the fact that there is very little metal transfer between the block and caps on #2 and #3
Do you mind posting pics of the metal transfer on the main caps, I'd be interested in seeing.......
I've got one just like you! Car run mid to high 6's in the 8th mile at 28-30psi and it finally gave up after about 6 years of abuse. This also included street driving.
This is what happened after I got the forged pistons....stock rod...same engine running the same times. This engine had 580HP to the rear wheels.
