I noticed there isn't an .xdf item defined for AE duration.  Helping a friend get his car dialed in before I have to PCS(move) and I was looking at the AE event during PE, I need it too last a little longer.  Now the filtering could help if I increase the AE amount and reduce the coeffiecient?
On another note, finally was able to get the alky going on my car. Works pretty well when controlled with the EBL, just need to figure out its happy spot. Also had to add a makeshift air bleed for the WG solenoid since it cant bypass enough pressure, boost only climbs to 16 psi. First time with the air bleed and the boost climbed to 25psi, blew right through 3rd gear before I could lift off the throttle. One count of knock at 25 psi right before lifting off the go pedal. Trans is the weak point now. Had to put the car away shortly after since it binged all of its alcohol, but Im happy with it right now.
