Couple more questions...
For PE enrich over time coefficient, Im trying to slow down the event a little bit. Finally brought my car out today to dial in the Akly settings, BTW. I would like to slow down the blend rate for this parameter and was wondering which direction, and possibly magnitude, to adjust the coefficient.
For WB solenoid; the cobbled together air bleed was not effective, the solenoid will only bypass enough to attain 16 psi, and doesn't matter how high the set point is. I don't like seeing another piece of hardware where it shouldn't be, so Im thinking of finding a solenoid that could bypass more, with larger ports. I found a possible solution in the Chevy 6.5TD trucks, can find a solenoid with pigtail for under 40 bucks. Reading the details online I noticed that it operates off of vacuum, but figured it has the same function. Any thoughts on if this will work by replacing the factory WG solenoid with this one?
Found them on ebay, but cannot display on work computers...
http://www.ssdieselsupply.com/p54_wastegateboost_solenoid_green_dot_94_97.html
The other option would be to use the dual solenoids and remove the restrictor, and tweak PW as needed?
